Thinking about Putting up Reservoir in High Rise Building
Chang Yuzhong* Gao Wei
      Shanxi Province Institute of Architectural Design & Research, Senior       Engineer
      Add:No.13 Str. Fudong Taiyuan Zip Code:030013
      Fax: 0351-3073613 Tel:0153-3285422
  ABSTRACT This paper discuss the viewpoint       that It is inadvisable to put up a eservoir for a single high rise       building in city.
        KEYWORDS Reservoir The fire water flowrate       Adjustable water
1 Introduction
  In the last decade, more then 100 high rise       buildings have set up in Taiyuan. All most every high rise building has a       reservoir for itself. In roughly evaluate, the areas of these reservoirs       reach 23000m2, the fee is high over 50 million RMB. So that if this case       occur all over our country, the fee would be high over 6000 million RMB.
        According to 《National Design Norm of High Rise       Building Fire System》No.7.3.2.1, when the civil water supply or natural       water sources can‘t supply fire water flowrate fully, It is necessary to       put up a fire reservoir in high rise building. According to 《National       Design Norm of Building Water Supply of adjustable water, reserving for       fire water flowrate and water for accident in producing. The amount of       water for accident in producing is no exist in common civil building, and       the amount of adjustable water is the difference between amount of       supplied water and maximum of used water . From that we can say waether       putting up a reservoir for civil building is depend on either the civil       water supply system can meet the needs of water of daily life of building       is depend on either the civil water supply system can meet the meeds of       water of daily life of building and fire water flowrate or can‘t, In       general, the fire water flowrate of building always bigger than water of       daily life. So that our opinion is that under the condition that civil       water supply system can meet the need of the fire water flowrate we can       don‘t putting up reservoirs for every high rise building.
2 Putting up reservoirs for every building in city is unsuitable
  To single building in city design of its outdoor       water supply system should depend on civil water supply system. However,       about design of city civil water supply system, the amount of adjustable       water of city and the fire water flowrate are considered fully. Although       city is changing with economic development, the needs of water increase       continually. We should see that civil construction has developing with the       civic development . To meet all kinds of need, the state of civil water       supply and the needs of water is remain balance. Since the design of civil       water supply system alr%ady consider the amount of adjustable water of       city and the fire water flowrate, putting up a reservoir for single       building to save this part of water is unnecessary. Although there is the       difference between the maximum of hourly using water in design of civil       water supply system and the flowrate per second in building design, we can       consider this problem in wide scope, events of using water take place in       different time and different places. So that the difference would be very       small, we could not care of it. For the more, the design of civil fire       fighting demand once using amount of water for putting out a fire in       anywhere and at anytime is over than 100L/s. As we know, the design of       city water supply consistent of water source,pressurize station and       pipe-network. Doing these designs depend on making the maximum of hourly       usingwater in city as essential parameter, And designs are checked by sum       of maximum of hourly using water in city and the fire water flowrate.       According to our analyses anyone system of civil water supply could meet       the needs of water for daily life of buildin and the fire water flowrater       in city. As a designer of building water supply and drainage, his design       of building water supply should be based on design of city water supply,       and he also should consider the actual conditions about location of       building.He must make a decision either put up a water tank or not       carefully. At present, because of lack of water source, some cities supply       the water by the method to different region in different time. In this       case, some high rise buildings lack of water supply sometimes. For this       special case, we can solve the problem by a temporary small water tank.       Inforward view, this case is not the property of city and foundation of       building water supply ,it well be changed with the civic development al       last, We say so because that:(1)this case is just a adjustment of civic       water source distribute by unit of city water supply. (2)human being can       change this state in anytime.(3)the ability of water supply that be       designed in design of city water supply still exist.(4)civil construction       has developing with the civic development. In sum, putting up a water tank       for single building repeat the total design of city water supply. Such       repeat is unsuitable and unnecessary.
        There are some branch offices of city waterworks or       region booster-pumping stations in medium or big cities, the branch       offices and booster-pumping stations are distribute uniformly. There are       some boosters and adjusting devices in the branch offices and       booster-pumping stations. The adjustable water of daily life, the water       dribbled as usual and must prepared the fire water flowrate of this region       have saved in the adjusting devices. Another hand, there are some boosters       and adjusting devices in the small residential quarters of city. Because       of reasons just we taking above, it is assured that the pressure reach       over0.15MPa under condition of maximum of hourly using water and the       pressure reach over 0.10 MPa under condition adding together maximum of       hourly using water and fire water flowrate. In the same time, there is a       high-level water tank on the high rise building usually,in which the       initial fire water flowrate and part water of daily life are stored.       Considering the conditions just we taking above, we think it is       unnecessary that putting up a water tank for single high rise building.
        We should iliustrate tha when for ru at anyWhe the unit       of dty water suPPly ho acts for important. When the fire department       receives the report of fire taking place at somewhere, he should tell the       unit of tw water supply in the region at once, switching on the pumps set       to work immediately and the the amount of water of civil water supply       pipe-network meets the demand of design of the system rapidly. The       cooperation in different departments is essential condition to accomplish       fire protection tasks perfectly
        Putting up a reservoir for high rise building has two       purposes, the first it is a device saving water for fire system, the       second it is a device saving adjustable water for daily life. But in our       discussing just taken, generally,civil water supply could meet the need of       single building in city, so that we needn‘t to put up a reservoir. On the       one hand putting up a reservoir for high rise building is unnecessary and       on the other hand it has some defects. There are 5 main defects in our       thinking.(1)Reservoir will occupy using area.At present usable land is       limited in city. So that the building functions have developed forward       space, just as we put up the water tank, water pump, air-condition       station, distrbutung substation,parking and so on in underground room as       usually. Therefor the underground room is very crowd. However the most       volume of reservoir is occupied by water for fire system,it is of no use       for a long time, even forever. It is regretful.(2)Putting up a reservoir       for one high rise building is every expensive.(3)The energy losing is too       big. Using a reservoir couldn‘t use the pressure of civil water supply       system fully, this is very wasteful of energy.(4)The quality of water is       polluted again. While water save in a reservoir for a long time, it is       possible to cause water to deteriorate.(5)The water for fire system no use       for a long time, that means reservoir is no use, but the daily maintain of       the device needs fee.
        Don‘t put up a reservoir for high rise building, we can       do that.(1)for water of daily life,put up a boost pump in pipe line of       civil water supply directly. Putting up a boost pressure pump can choose       different size in different region, just as having a reservoir.(2)for       water of fire system, we should put up two pipe line of civil water supply       from different directions. The diameter of pipeline can be increased       properly, the pipe line can form independent system, and putting up a fire       pump in pipe line. Putting up fire pump can choose different size in       different region, just as having a reservoir.(2)for water of fire system,       we should put up two pipe line of civil water supply from different       directions . The diameter of pipeline can be in creased properly, the pipe       line can form independent system, and putting up a fire pump in pipe line.       Putting up fire pump can choose different size in different region, the       design of the other fire devices and control methods is the same just as       having reservoirs. Fire departments are set up in different regions of       city. The fire departments distribute depent on the distance the fire       department could reach the fire spot no more then ten minutes. When fire       occurs, building manager should switch on fire pump and other fire       fighting devices, at the same time, report to fire department and unit of       civil water supply. They can do these works in short time. Therefor we       needn‘t put up a reservoir for a building.
        Under special cases,(1)The high rise buildings are       constructed at suburb, the state of civil water supply is bad indeed or       the character of buildings is important especially. We can consider put up       a reservoir for a building,(2)At the area that high rise buildings are       very crowd, we can set up a reservoir and booster-pumping station for the       region. It is efficient.
3 Conclusion
It is unnecessary that putting up a water tank for single high rise building in city. Doing not put up water tank is no affect to water of daily life and the fire water flowrate. Doing not put up water tank we can make good use of environment and limited energy.
References
[1]People‘s Republic of China Public Security Ministry《The National Design Norm of High Rise Civil Building Fire System》GB50045-95 1995.11.
相关推荐
- 中国城市绿道雨洪管理研究(英文)
- 枣椰仁颗粒活性碳及其在多介质过滤器中余氯穿透曲线动态建模(英文)
- Study on the relationship between the decomposition rate of ozone and the removal rate of MTBE in catalytic ozonation
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Separation of Sulfur/Gasoline Mixture with Polydimethylsiloxane/Polyetherimide Composite Membranes by Pervaporation
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
