哈尔滨气化厂(达连河)供水系统应对硝基苯污染的措施与效果
| 论文类型 | 技术与工程 | 发表日期 | 2006-07-01 |
| 来源 | 中国水网 | ||
| 作者 | 崔福义,李伟光,张悦,赵志伟,姜殿臣,韩 | ||
| 关键词 | 硝基苯 粉末活性炭 强化混凝 炭砂滤池 应急供水 | ||
| 摘要 | 本文介绍了哈尔滨气化厂(达连河)供水水源受硝基苯污染及应急供水措施的制定与实施情况,评价了应急供水工艺对硝基苯的实际去除效果。实践证明,所采取的原水中投加粉末活性炭、强化混凝沉淀、炭砂滤池等应急措施有效可靠,在硝基苯最高超标倍数达到14.22倍的情况下,保证了供水水质,实现了不中断供水的目标。粉末活性炭起到了主要的去除硝基苯作用,在取水口投加、利用11.9km长的输水管道保证充分的吸附时间是技术成功的关键。此次成功的应急供水积累了宝贵的经验,可以供进一步研究参考。 | ||
哈尔滨气化厂(达连河)供水系统应对硝基苯污染的措施与效果 崔福义1 李伟光1 张悦2 赵志伟1 姜殿臣3 韩雪东3 吕德全3 牛玉梅3 张振宇1 (1哈尔滨工业大学 黑龙江 哈尔滨 150090 2.建设部城市建设司 北京 100835 3哈尔滨气化厂 黑龙江 哈尔滨 154854) 摘要:本文介绍了哈尔滨气化厂(达连河)供水水源受硝基苯污染及应急供水措施的制定与实施情况,评价了应急供水工艺对硝基苯的实际去除效果。实践证明,所采取的原水中投加粉末活性炭、强化混凝沉淀、炭砂滤池等应急措施有效可靠,在硝基苯最高超标倍数达到14.22倍的情况下,保证了供水水质,实现了不中断供水的目标。粉末活性炭起到了主要的去除硝基苯作用,在取水口投加、利用11.9km长的输水管道保证充分的吸附时间是技术成功的关键。此次成功的应急供水积累了宝贵的经验,可以供进一步研究参考。 Approach and Effect of Removing Nitrobenzene Pollution in Harbin Gasification Plant (Dalianhe) Water Supply System Cui Fuyi1 Li Weiguang1 Zhang Yue2 Zhao Zhiwei1 Han Xuedong3 Lv Dequan3 Zhang Zhenyu1 (1 Harbin Institute of Technology, Harbin 150090, China 2.Urben Construction Department of Construction Ministry Beijing 100835 3 Harbin Gasification Plant 154854) Abstract: The paper introduces the nitrobenzene pollution of water source of harbin gasification plant (dalianhe) and the emergent approach of water supply, evaluates the removing effect of nitrobenzene of the emergent process. It is proved that feeding PAC, enhanced coagulation sedimentation and carbon-sand filter are all effective and dependable emergent approaches. Under the condition of the maximum times of nitrobenzene over the standard up to 14.22,the approaches can guarantee the standard water supply and the continuous water supply. PAC play an important role in this process .The key technique is feeding PAC at the intake and keep the enough adsorption time by means of the 11.9km pipe. The successful emergent water supply approach has accumulated rich experience which can be used as a good reference for the further study. Key words: nitrobenzene, PAC,enhanced coagulation, carbon-sand filter, water supply in emergency 2005年11月13日,吉化公司双苯厂爆炸导致松花江水体受到硝基苯严重污染,给沿江城市和工矿企业用水安全带来严重威胁,位于哈尔滨市城区下游达连河镇的哈尔滨气化厂供水同样面临严峻的考验。11月29日,受建设部和黑龙江省、哈尔滨市政府委托,以张悦为组长、崔福义为技术负责人的专家组急赴达连河,应对松花江水污染。专家组在达连河奋战9昼夜,成功地解决了污染带来的问题,确保气化厂供水不中断,从而保证了哈尔滨市人民燃气供应正常。本文拟对此次应对污染的情况进行介绍。 1. 哈尔滨气化厂供水概况 哈尔滨气化厂地处哈尔滨市依兰县达连河镇,位于松花江南岸,距哈尔滨市城区下游300多公里,承担着向哈尔滨市76万户居民,3000余户工业企业和商服用户供应燃气的任务。其供水分厂负责气化厂生产用水的供应,生产供水量为5万m3/d,以松花江水为水源。气化厂供水分厂水处理工艺见图1。松花江原水由江心取水头进入岸边取水泵房,水泵加压后经11.9km长、直径800mm的输水管送入厂内稳压井;在稳压井投加液体聚合铝混凝剂后进入反应池和沉淀池,然后经煤砂双层滤池过滤、消毒后进入清水池备用。
图1水厂水处理工艺 2. 应急供水技术方案 松花江是气化厂唯一的供水水源。由于厂内储水能力仅能维持几个小时的供水,一旦硝基苯超标导致水厂停产、供水中断、造成气化厂停产,将给哈尔滨市人民生活与生产带来十分严重的影响和后果。为此,省市政府明确提出要求,必须采取有力措施,确保在松花江水受到硝基苯污染的情况下,保证供水水质合格,保证气化厂生产安全和哈尔滨市的燃气供应。因此,确保任何情况下不中断供水,是此次应急供水的目标。 3. 应急供水实施效果 2005年12月2日11时,松花江达连河断面首次检出硝基苯为0.01288mg/L,此后硝基苯浓度在波动中增加,至12月5日14时达到最大值,超标14.22倍,此后又在波动中下降,至12月8日17时,降至标准值以下。具体变化情况见图2。与上游各断面情况比较,达连河断面硝基苯超标倍数进一步下降,超标持续时间延长,浓度波动增强。
图2 达连河段面硝基苯浓度变化 3.1粉末活性炭对硝基苯的吸附效果 粉末活性炭炭种为唐山生产的木质炭,主要性能指标见表1。 表1 应急供水用粉末活性炭主要性能指标
在污染团到达前,通过模拟试验确定了不同硝基苯超标倍数下的最佳粉末活性炭投加量,得到的结论是吸附时间应保证在2h以上,对应不同超标倍数下的投炭量见表2,可以将硝基苯吸附去除到标准值以内。 表2 不同超标倍数下的投炭量
在应急供水生产上,考虑到水样检测存在滞后,以及水质的波动因素,为了确保安全可靠,在试验数据基础上,适当提高炭投加量。获得的实际吸附去除效果按炭投加量区分,见图3、4、5所示。
由图3、4、5可见,在各种原水硝基苯浓度超标倍数下,通过调整PAC投量,可以保证硝基苯的平均去除率达到95%左右,一般不低于90%。这些生产性数据和实验室烧杯试验的结果相近,但是去除率要低2~3个百分点,这是由于操作条件不同造成的。数据说明以烧杯试验模拟生产情况、指导生产运行是可行的。
图6 混凝沉淀对硝基苯的去除效果 3.3炭砂滤池的运行及对硝基苯的去除作用
3.4硝基苯总体去除情况
4. 结论 (1)实践证明,所采用的应急技术方案是完全正确的,粉末活性炭、强化混凝沉淀、炭砂滤池构成了应急供水的多级处理环节,各自发挥着特定的作用。上述应急工艺保证了在硝基苯最大超标14.22倍的情况下,供水中残留硝基苯始终未超标,实现了不中断供水的目标。 |
