Hunters Probability Method Applied to Determine Water Supply
| 论文类型 | 技术与工程 | 发表日期 | 2007-01-01 |
| 作者 | Zhang,Minghua,Gao,Yu | ||
| 关键词 | design second flow frequency of fixture use water supply reliability program operation | ||
| 摘要 | This article discusses the calculation of design second flow in the buildings of residents, and studies two important factors influencing design flow step by step. | ||
            Hunter‘s Probability Method Applied to               Determine Water Supply Design Second Flow in Buildings of Residents
Zhang Minghua Gao Yufei
                      Xi‘an University of Architeture and Technology                        School of Environment & Municipal Engineering
          Add:No.13 YanTaRd, Xi‘an, Code:710055
ABSTRACT This article discusses the calculation of design                        second flow in the buildings of residents, and studies two important                        factors influencing design flow step by step.
                       KEYWORDS design second flow in the buildings of residents ,                        frequency of fixture use, water supply reliability, program                        operation
1、 At present the calculation about design second flow in the buildings of residents and some problems
According to the current norm《water supply and water drainage of buildings design norm》(GBJ15-88)(is called《design norml》for short as below).The calculation about design second flow in the buildings of residents is given as below:
qg=0.2α(Ng)1/2+KNg (1)
 here qg is the design flow of the calculated                        pipe line;
                       Ng is the equivalent of sanitary fixtures of the                        calculated pipe line;
                        α=1.02,K=0.0045;
                        This formula comes from original norm 《water                        supply、 water drainage and hot water supply design norm》(TJ15-74),where                        the formula about design flow is qg=0.2α(Ng)1/2+KNg,which                        is so-called the law of square root. Eq.(1)is based on the formula                        in 《design norm》(TJ15-74)according to former measured data. Eq.                        (1)is established by probability analysis, which is the first                        formula according to our country‘s actual situation, but it is also                        subordinate to the scope of the law of square root. As the                        accidental chance of measured data, and at that time the limitation                        of life standard, this formula is not highly reliable in theory and                        practice, which can‘t meet actual demands to a certain extent.
                        Some main problems exists in Eq.(1):
                       (1)It considers only non-uniformity of water                        usage, while doesn‘t embody the random of water usage.
                        (2)It can‘t reflect various factors influencing                        water consumption such as the number of people served by fixtures,                        various combination forms of different fixtures, water supply                        system.
                        (3)It can‘t reflect the design flow compared to                        different water consumption quota.
                        (4)It is about the value of α K at 3 different                        situations listed by 《design norm》(GBJ15-88).
1. Hunter‘s probability method‘s theoretical deference and some problems needed to resolve in our country
 When calculating the design second flow in the                        buildings of residents, we need analyze all possible variable, then                        get the optimum system meeting the demand. Although the number of                        people engaged in studies of water supply (installations) is not so                        large, research activity has grown considerably both in Japan and                        other countries. In the past many developments have taken place and                        new techniques are being introduced in practice. It has now become                        mandatory to analyze and protect the environment from sewage and                        water pollution problems. Keeping this in view, it has become                        increasingly important to carry out further studies based on new                        ideas on water supply fixtures and develop a new perspective toward                        design methods and design data. At present, Hunter‘s probability                        method is used broadly in America、 Japan and many European                        countries.
                        The theory of Hunter‘s probability method is                        established as shown:
                        It was put forward by A American Roy. B. Hunter                        in 1924 and further made more perfect in 1940.He made highly                        practical charts. Its basic principle is. the use of sanitary                        fixtures in the system is assumed as an accidental event, which is                        depicted by the mathematics model of the binomial distribution. It                        is supposed N sanitary fixtures is linked at a certain pipe line,                        while every fixture is turned on and turned off independently. The                        quota of flow of every sanitary fixtures is q0, and the maximum                        water supply second flow is q0N, the minimum water supply second                        flow is 0, then the water supply flow at random passing though the                        calculated pipe line is defined as q (0≤q≤q0N). when designing                        the system, we have to consider meeting the consumer‘s need and                        economical feasibility. So we can simply study the extreme                        situation, exactly water consumption at high hour in high day. It is                        supposed the frequency of each sanitary fixture use at high hour is                        p, the the non-frequency of its use is (1-p). So the probability                        that I fixtures is simultaneously used among N fixtures at maximum                        is given as shown:
P(x-i)=CiNPi(1-P)(N-1) (2)
According to Hunter‘s definition, the probability value about single system which is consisted of a single sanitary fixture is shown as below:
Here Pm the probability value of simultaneously use of m fixtures                        at most;
                        M is the design value of simultaneous use of                        sanitary fixtures;
                        P is the use probability of single fixture at                        water consumption peek time;
                        Pr is the guarantee value of water supply;
                        Hunter‘s method is more scientific, while the                        calculation result with it differs variously compared with Eq. (1).                        The main reason is:
                        (1)Although t/T about sanitary fixtures in                        Hunter‘s method is based on the investigation of hotel and                        household, as a result of the difference of the character of                        buildings、life custom district, we need study the value is whether                        reasonable and whether accords with our country‘s actual situation.
                        (2)Hunter‘s calculation curve can be applied in                        flush valve, while Eq.(1) can‘t be used in flush valve in our                        country.
                        (3)The style of sanitary fixtures is different .                        In Hunter‘s curve, water supply flow rate of flush tank and bathtub                        is 0.25l/s and 0.51l/s separately, which is much larger than                        0.1l/sand O.2l/s in our country.
                         (4) The guarantee value of Hunter‘s probability method is                        O.99, which is a supposed value .It is needed to study how to                        determine the specific guarantee value.
                       It is considered by analysis of Hunter‘s method that theoretically                        the probability of sanitary fixture use is the same, the peek time                        of fixtures use only exits at water consumption peek time by actual analysis                        ,so it is needed to determine the time length of peek time of                        sanitary fixtures use, not just given 24 hour.
                       3. two important parameter influencing design second flow
                         (1) probability value of fixtures use The definition formula                        of probability P is p=t/T, here T is time interval of fixtures used                        continuously twice, t is time length of every water usage.
                       We can see from the definition formula:
                        (1) It is related to water consumption standard                        .The normal is more high ,the number of water use and time length of                        water use both increase ,so the value of p becomes large;
                        (2) It is related to total number of fixtures                        liked at designed pipe line .With the increasing of total number,                        the value of P decreases. The researcher in Japan has made actual                        investigation ,as shown in table 1:
Probability of simultaneous use of various equipment (%) table.l
probability value 1 2 4 8 12 16 24 32 40 50 70 100 Flush valve 100 50 50 40 30 27 23 19 17 15 12 10 general
equipment 100 100 70 55 48 45 42 40 39 38 35 33
 (3) It is related with the number of people                        served by fixtures .The number is much larger, the value of is                        larger;
                        (4) It is concerned with combination form of                        fixtures.
                        (5) It is concerned with the style of sanitary                        fixtures .For examlple ,flush water volume of Flush tank differs                        from 2L to 12L .At other same conditions, the ratio between maximum                        probability value and minimum probability value is 6, varying much                        largely.
                        (6) It is related to the value of T. Water use                        time of family is 18h-24h listed in 《designnorm》 .Actually the                        peek time is commonly at 6AM-10AM, 6PM-1OPM. The probability value                        is 2-3 much larger than the time used with 18h-24h.
                        In fact the design flow in buildings of residents                        is related to sex-age structure of residents、 people‘s behavior .                        means of water use 、 climate and so on. As the use probability is                        a multi- factor value, it is impossible to take all influencing                        factors into consideration. We have to just consider some important                        factors. At present as a result of measured level 、 research funds、                        and understanding about this in our country, we can‘t make                        systematic and effective investigation(in Japan it needs about 5-6                        years). We should not only collect data about this to accumulate                        experience, but also use the experience of other countries similar                        to our country in climate and life custom. The bble.2 as below shows                        the investigation in Japan about water consumption of families,                        which mainly accords to my investigation. The probability got is                        based on table.2.
                        (2) reliability of water supply
                        As water supply system belongs to the scope of                        service system, it is required that the value of reliability should                        be determined by customers‘ demand. In the norm 《Fundamental terms                        anddefinitoion of reliability》,the definition of reliability R is:                        the product‘s capacity to accomplish the formulated function at                        formulated conditions in formulated time.
times of water use in buildings of residents(in summer) table.2
0.6×24=14.4≤t<19.2 t<14.4 infant, professional housewife, old people child, students, professional housewife college student, husband(employment),wife(employment) t≥19.2
14.4≤t<19.2
t<14.4 times of defecation (times/person.weekly) times of urination (times/person.weekly) male female male female number of family infant or not times of bathing(times/per.weekly) times of showering(times/per.weekly) times of water supply of bathing (times/cap.weekly) times of washing(times/cap.weekly) 2w N 3.0(2.5) 4.0(3.0) 2.8 6.5 Y 3.4(2.5) 3.6(3.0) 3.4 9.5 3人 N 4.5(3.0) 2.5(3.5) 4.5 11.0 Y 3.8(3.0) 3.2(3.5) 3.8 10.5 4人 Y 4.0(2.8) 3.0(3.5) 4.0 14.5 N 4.1(3.0) 2.9(3.5) 4.1 13.0 5人 Y 3.5(3.0) 3.5(3.0) 3.5 17.0
 Note:the number in brackets is got by the                        author in the year of 2000 due to the residents of Xi‘an                        Architecture and Technology University.
                    A ccording to the character of water use,                        requirement of water supply reliability is determined in economical                        principle and by the necessity of sanitary condition of buildings                        and life service normal. In all situations, reliability of the                        system requires that when function of water supply is destroyed, it                        should meet people‘s demand without any influence.
                        Due to municipal water supply system, it is                        complicated to determined working parameter of system (such as the                        unit of water use 、time duration of water use 、 time length of                        water use ). It is feasible to take any effective control of water                        consumption due to such water supply system as the service system.                        Design index of system function and the limitation of allowance is                        determined according to the character of wervice objects, which also                        determine the grantee value of water supply reliability. But the                        problem of investment also exists. The grantee value is larger, then                        the investment is higher, increasing burden of service objects so it                        dissatisfies service objects. We must take full consideration of                        grantee value and investment, so the optimum problem exits. Table.3                        is qualification disposal of water supply reliability.
Qualification disposal of reliability table.3
Pr average possibility of water breaking possibility of water breaking at peek time time of water breaking in a year(h) time of water breaking in a month time of water breaking in d day (s) (min) 0.9875 0.0125 0.0375 109.5 9.125 1080 18 0.99 0.01 0.03 87.6 7.3 864 14.4 0.995 0.005 0.015 43.8 3.65 432 7.2 0.997 0.003 0.009 26.28 2.19 259.2 4.32 0.999 0.001 0.003 8.76 0.76 86.4 1.44
 Note:(1) 0.9875 is a grantee value applied in                        our country‘s design normal
                        (2)0.99 is a                        grantee value applied in Russian design normal
                        (3)0.997 is a                        grantee value just for determining the extent of influencing
                        (5)a year is                        consisted of 365 days; the peek time length of water use is 8h
 From table.3, it is shown when the grantee value is 0.995、0.997、0.999                        or much larger, it does not influence life of people much bitterly.
                       4、drawing up program and contrast
                        This program is drawn up in computer language              Foxbase, having the character of simple debugging and great speed.                        It can be run in Visual Fox, suit for designers. The result of                        debugging is shown as below:
                        Attention: Every family consists of 3.5 persons;                        the volume of flush tank is supposed 7L; the probability of washing                        use is calculated due to table.2; the time length of water use is                        8h. We can get the use probability of bathtub is 0.024;probability                        of washing basin is 0.022.
                   Probability of flush tank is 0.045;probability of flush                  valve is 0.0033;probability of showering is 0.0167;probability of                  bathtub is 0.024;probability of washing basin is 0.022.
                       In table.4、table5、table.6 a=1.02 and K=0.0045
                       (1)3 different grantee value(0.99、0.995、0.999),                        contrast of design second flow
contrast of number of washing basin by probability method table.4
[296,323]
contrast of number of simultaneous use of showering by probability method table.5
contrast of number of simultaneous use of washing basin by probability method table.6
Note in bable.4、table.5、table6 [45,55] denotes that the                        number of sanitary fixtures simultaneous use is the same.
                       Figure.1、figure.2、figure.3 shows the contrast of design second                        flow at 3 different grantee value.
                        (2)contrast of design second flow between                        probability method and normal formula
 By analysis, we can see that grantee value of                        water supply reliability does not influence design second flow much                        bitterly. To compare with the result we suppose Pr=0.9875.
                        The use of mixed fixtures can‘t be simply added                        by such single fixture. obviously less than the added result. A                        Japan researcher poses that flow of simultaneous use of different                        fixtures is the maximum flow of single fixture use added half flow                        of other single fixture.
                        According to his research. we can get figure.4 as                        below.
5、conclusion
                       We can draw such conclusion by analysis:
                        (1)The design second flow got by Hunter‘s                        probability method is much less than what is got by normal formula.                        The main reason is at an accurate probability value condition , the                        value of Pr has much influence on design second flow. So it is                        meaningful to determine the probability meeting actual demand. This                        needs us to do full and accurate investigation.
                        (2)Form the result and the figures, we can see                        when Pr is a fixed value in spite of different number of fixtures,                        the value of Pm is different (Pm≥Pr). When the number of                        simultaneous use is the same ,the number of total fixtures is in a                        value scope, that is to say the value of the design second flow is                        more separated.
                        (3)This character does researches at the water                        use behavior of people and get the more convincing probability of                        fixtures use . We get the calculation method considering economic                        and feasibility.
                        (4)Hunter‘s probability method is more scientific                        and more reliable than the normal formula.
相关推荐
- 中国城市绿道雨洪管理研究(英文)
- MAXFLOW叶轮在高密度沉淀池工艺上的应用
- Nitrifying Population Optimization in Municipal Saline Wastewater Treatment
- Characterization of the start-up period of single-step autotrophic nitrogen removal in a sequencing batch reactor
- Artificial neural network modeling of water quality of the Yangtze River system: a case study in reaches crossing the city of Chongqing
- RES EARCH ON MEMBRANE B IOREACTOR TREATING DOMES TIC WAS TEWATER AND RELATED MECHAN ISMS
