Effectiveness and mechanism of potassium ferrate(VI)
| 论文类型 | 技术与工程 | 发表日期 | 2005-06-01 |
| 来源 | 中国水网 | ||
| 作者 | 马军,Wei,Liu | ||
| 关键词 | Potassium ferrate Algae Preoxidation Coagulation | ||
| 摘要 | Jar tests were conducted to evaluate the effectiveness of potassium ferrate preoxidation on algae removal by coagulation. Laboratory studies demonstrated that pretreatment with potassium ferrate obviously enhanced the algae removal by coagulation with alu | ||
Jun Ma*, Wei Liu
        School of Municipal and Environmental Engineering, Harbin Institute of         Technology, PO Box 2627, 202 Haihe Road,Harbin 150090, People’s Republic         of China
        Received 17 October 2000; received in revised form 1 June 2001; accepted         18 June 2001
Abstract
        Jar tests were conducted to evaluate the effectiveness of potassium ferrate         preoxidation on algae removal by coagulation. Laboratory studies demonstrated         that pretreatment with potassium ferrate obviously enhanced the algae         removal by coagulation with alum [Al2(SO4)3  18H2O]. Algae removal efficiency         increased remarkably when the water was pretreated with ferrate. A very         short time of preoxidation was enough to achieve substantial algae removal         efficiency, and the effectiveness was further increased at a prolonged         pretreatment time. Pretreatment with ferrate resulted in a reduction of         alum dosage required to cause an efficient coagulation for algae removal.         The obvious impact of cell architecture by potassium ferrate was found         through scanning electron microscopy. Upon oxidation with ferrate, the         cells were inactivated and some intracellular and extracelluar components         were released into the water, which may be helpful to the coagulation         by their bridging effect. Efficient removal of algae by potassium ferrate         preoxidation is believed to be a consequence of several process mechanisms.         Ferrate preoxidation inactivated algae, induced the formation of coagulant         aid, which are the cellular components secreted by algal cells. The coagulation         was also improved by increasing particle concentration in water, because         of the formation of the intermediate forms of precipitant iron species         during preoxidation. In addition, it was also observed that ferrate preoxidation         caused algae agglomerate formation before the addition of coagulant, the         subsequent application of alum resulted in further coagulation. r 2002         Elsevier Science Ltd. All rights reserved.
        Keywords: Potassium ferrate; Algae; Preoxidation; Coagulation;         Enhanced coagulation; Oxidation
        1. Introduction
        The eutrophication of surface water is a worldwide problem, which is increasing         in significance. Eutrophication is caused by excessive inputs of nutrients,         especially phosphorus, that stimulate nuisance growth of algae. The omnipresence         of algae caused by the eutrophication
        of surface water is the current and growing problem in the production         of drinking water. To control the massive growth of algae in lakes and         reservoirs, the impact of some chemicals such as copper sulphate, potassium         permanganate, on algae were studied. Copper sulphate [CuSO4  5H2O] has         been used to control nuisance algae in lakes and reservoirs for more than         80 years, and is considered to be an effective algicide available [1].         Potassium permanganate was also studied on the specific use as an algicide         for reservoirs [2,3].
        In drinking water treatment, conventional coagulation is still the main         treatment process for algae removal. Whereas other treatment processes,         for example, dissolved air flotation [4], sand filtration [5], direct         filtration [6], which are aimed at algae removal, have also been researched.         Massive growths of algae have caused many problems. Some algae cause uncomfortable         tastes and odors, some algae cause filter clogging, some algae can penetrate         the filter, leading to the deterioration of drinking water quality. Algae         is also a precursor of
        disinfection by-products. Algae removal from water treatment process is         difficult because of their small size and the low specific gravity. It         was reported that pre-treatment with oxidants may enhance the coagulation         process and specifically enhance the removal of algae and other particulate         matters in subsequent treatment steps [7–9]. The effects of chlorine,         ozone and chlorine dioxide on Scenedesmus
        sp. cultures were studied [10]. Algal cells activity and chlorophyll concentration         decreased, and the concentration
        of dissolved organic substances increased with increasing applied oxidant         concentration. It was found that pretreatment with chlorine dioxide (1,         3 or 5 mg/l) or ozone (2.6, 4.6 or 8.1 mg/l) on algal cultures enhanced         algal coagulation with aluminium sulphate, while prechlorination with         10 or 20 mg/l chlorine increased the required dosage of alum by 15%. However,         the negative effect of using chlorine and chlorine dioxide resulting from         the formation of by-products are limiting the use of these chemicals as         pre-oxidants. In addition, it was recently recognized that the ozonation         of waters containing bromide may lead to the formation of bromate at a         level suspected of being hazardous to health, which is a negative aspect         for using ozone as a preoxidant. Potassium permanganate has been investigated         as an alternative preoxidant for the direct filtration of impounded surface         water. The experiments of modified jar test apparatus and pilot plants         showed that permanganate pre-treatment followed by coagulation with dual         coagulants (ferric sulphate and cationic polymer) distinctly improved         the particle and algae removal commonly achieved in direct filtration         [6]. It is suggested that the common mechanism of algae removal by oxidant         is the destruction of the algae architecture to various extent through         different ways of oxidation.
        Potassium ferrate [K2FeO4] is another strong oxidizing agent, which has         a strong redox potential through the entire pH range, ranging from 2.2V         in acid to 0.7V in base [11]. Several investigations have been conducted         in applying potassium ferrate as a favorable alternative disinfection         to chlorine for the disinfection of water and wastewater [12,13]. It is         found that ferrate(VI) ion appeared to be an effective antifoulant [14],         as only short contact times were required for ferrate concentration of         105M to control the biofilm growth. In addition, recent study found that         ferrate treatment did not produce any mutagenic by-products during the         treatment process [15]. The effects of pre-treatment with ferrate(VI)         ion on algae coagulation by aluminium sulphate was investigated in this         paper. Also, the effects of the pre-oxidation by ferrate on algae cell         surface architecture and dissolved organic materials (DOM) of samples         were studied by scanning electron microscopy (SEM) and UV spectrophotometer,         respectively.
        2. Materials and methods
        2.1. Raw lake water
        Raw water of shallow lake located in northeast part of China, which is         in deep green color indicating high algal concentration, was selected         in this study. Observation results by microscopy shows that the lake water         principally contains green algae, such as Chlorella,
        Spirogyra, Chlorococoum, Scenedesmus etc. The raw water quality was listed         as follows: Turbidity 10–30 NTU; pH 7.5–7.7; temperature 15–181C; algal         concentration 8106–2107 cells/l, CODMn(permanganate index) 10.5 mg/l         (measured after filtration with 0.45 mm membrane).
        2.2. Culture conditions
        A solution containing cultured green algae species was also used in this         study in order to overcome the influence of other materials except algae         in natural surface water on experimental results. Algae species chosen         in cultured process are Chlorococoum and Scenedesmus, because
        they are commonly found in natural waters and are typical green algaes.         It is also because that they are easily available and are easily cultured         in the laboratory. The algae seeds were cultured in the plastic culture         tank containing total 280 l modified inorganic nutrient solution (the         concentration of inorganic salts that contained in the solution is listed         in Table 1), in which 200 ml soil exudation liquid was mixed. The starting         cell concentration in the water was 4106 cells/l at a constant temperature         of 15711C, pH 7.3. Continuous light was provided by incandescent lamp         and daylight lamp. A gas mixture (1% CO2 in air) was bubbled into the         medium for a period of 15 min every other day. After grown for 25 days,         algal concentration in nutrient
        solution achieved 3.5–4.2108 cells/l, pH 9.1, turbidity20–40 NTU, CODMn(permanganate         index) 5.2 mg/l(measured after filtration with 0.45 mm).
        2.3. Coagulation tests
        Standard jar tests were conducted in a mixer equipped with six-paddle         jar test apparatus. The effects of various dosages of aluminium sulphate         [Al2(SO4)3  18H2O] on cell coagulation with and without preoxidation         was tested in six 0.5 l beakers. The pH of each 0.5 l cultured sample         was adjusted to 7.1 with 1N HCl. Potassium ferrate [K2FeO4] was prepared         by the modification of the method of reaction between OCl– and Fe(OH)3         (gel) in strongly basic media and isolated from saturated KOH solution         [16]. The chemical solution was transferred
        into six test tubes fixed on one stick and injected into the individual         sample simultaneously by rotating the stick in order to minimize the systematic         errors resulting from differences in the time of addition. A carefully         calculated amount of potassium ferrate solution
        was injected into beakers a certain time before the addition of alum solution.         The freshly prepared alum solution using analytical reagent was predetermined         (10 mg/l aluminium sulphate). During ferrate and alum addition, samples         were stirred at 200 rpm for 1 min and then at 45 rpm for 10 min. Afterwards,         samples were allowed to settle quiescently for 20 min. Thereafter, the         upper 100 ml of the water sample was siphoned 1 cm below the water surface         and taken for determination of residual algae cell concentration. In the         case of lake water, the settled samples were further filtered with filter         paper (1–2 mm pore size), and the residual algal concentration after filtration         was also determined. Residual algal concentration after coagulation test         was determined by microscope counting of cells.
        2.4. Scanning electron microscopy
        A blob of treated algae solution by potassium ferrate oxidation and the         control algae solution without ferrate oxidation were dried for 2 h in         the drying table, and they were gold-coated to a calculated coating thickness         of 150nm by Eiko IB-3 ion emitting apparatus. Then, they
        were examined in a Hitachi S-520 scanning electron microscope operated         at 15 KV.
        2.5. UVA at 254 nm and UVA scanning
        The scanning of ultraviolet absorbance was performed at the wavelength         ranging from 200nm to 320nm of untreated and treated cultured samples         after filtered with a 0.45 mm cellulose acetate membrane filter. The absorbance         of ultraviolet absorbance at 254nm was also determined. The absorbance         of ultraviolet at 254nm by natural waters is a semi-quantitative indicator         of the concentration of natural organic materials (NOM) in water. In water         treatment practice, the use of absorbance at 254nm has been found to be         useful for monitoring the concentration of DOC [17]. UV absorbance was         also used to characterise NOM by the degree of its aromaticity. UVA at         254nm and UVA scanning were used in this study to indicate the variation         of dissolved organic materials (DOM) in cultured solutions during different         treatment processes.
        3. Results and discussion
        3.1. Effects of ferrate preoxidation on coagulation
        Fig. 1 shows the effects of increasing ferrate concentration on algae         removal by coagulation with alum. The removal efficiency is expressed         as the ratio of the algal concentration before addition of chemicals to         the algal concentration measured at the end of the coagulationsedimentation         test. It can be seen that alum coagulation partially removed the algal         cells in lake water, 20–30% of algae removal was achieved at the low alum         dosage of 20–50 mg/l; 50% of algae removal was observed at higher alum         dosage (e.g. 80 mg/l, see Fig. 1a). While in
        the case of cultured solution, substantial algae removal was observed         with alum coagulation alone in whole range of alum dosages (Fig. 1b).         Thus the difference of algae removal between the case of coagulation alone         and that with ferrate preoxidation was not very obvious for
        cultured water. It is worth noting that there was a sharp increase of         algae removal efficiency when the alum dosages were between 50–60 mg/l         in lake water and 40–50 mg/l in cultured solution at the case with alum         only. This indicates an optimum dosage range of alum for
        effective coagulation of algal cells, due to the conceivable isoelectric         point between the alum and algal cells. The figure shows that ferrate         preoxidation has obvious effect on the coagulation of algae in either         lake water or cultured solution. At any coagulant dosages
        adopted in the tests the algae removal of settled samples pretreated with         ferrate is higher than that without ferrate pretreatment. Even if ferrate         dosage is only 1 mg/l, an obvious effect of algae reduction can be observed.         Meanwhile, the removal efficiency increased gradually with the increase         of alum dosage when pretreated by ferrate without an obvious isoelectric         point especially in cultured solution, and this lead to a relative wider         optimum coagulant dosage range for the removal of algae. Pretreatment         with ferrate remarkably enhanced the algae removal, so that the alum dosage         required for achieving a certain algae removal efficiency can be reduced.         With the continuing increase of ferrate dosages, the residual algae removal         increased further. Algal biocolloids carry negative surface charges at         most pH levels [18], and the basic mechanism of iron- or
        aluminium-hydroxide coagulation consists in mutual attraction and neutralization         of the charge by the positively-charged hydroxide coagulant. While, it         has been previously demonstrated that the NOM have a very strong influence         on coagulation effectiveness. In
        the presence of NOM, the coagulant reacts first with the free natural         organic acids, e.g. humic acids and fulvic acids in waters, and only when         the coagulant dosages are high enough to neutralize the surface charges         of the organic materials can the coagulant take part in the electro-neutralization         and bridging process [22]. Those observations lead to the conclusion that         the NOM contained in surface water result in different algae removal between         lake water and cultured solution which is lack of natural organic materials,         when treated with alum alone (see Fig. 1). Meanwhile, the effects of ferrate         preoxidation on algae removal in the case of lake water is more significant         than that in cultured solution. It is believed that these effects are         attributed to ferrate preoxidation, in which ferrate act as an aid to
        coagulation processes [19].
        The effect of various pretreatment times on algae removal by coagulation         was tested (see Fig. 2). Algae removal efficiency increased obviously         even in a short preoxidation time (as 1 min), and the removal efficiency         further increases with the continuing extension of the
        contacting time. Due to the slight increase of removal efficiency with         the extension of pretreatment times (longer than 1 min), it was suggested         that pretreatment with ferrate can influence the surface characteristics         of algal cells in a very short time of oxidation and thus cause an enhanced         coagulation.
        In addition, the residual algae removal rate preoxidized with ferrate         is further increased after filtered with 1–2 mm pore size filter papers,         as shown in Fig. 3, indicating that the filtration process accentuated         the effects of ferrate preoxidation on algae removal. The
        algal cells after ferrate preoxidation and alum coagulation are easily         intercepted by the filter, which otherwise did not precipitated within         the sedimentation stage.
        3.2. Effects of ferrate preoxidation on algal cell surface architecture
        The scanning electron microscopy (SEM) was used to provide additional         information that was essential to better describe the underlying process         mechanisms. Typical appearance of Scenedesmus (Fig. 4a) under our cultivation         condition showed four cells coenobia with two spines arising from the         ends of each terminal cells. All four cells have approximately the same         dimensions. The cells were enclosed by a sheath (here referred to as the         reticulate layer) [20]. Randomly scattered warts on the cell surface were         clearly seen, which is the typical
        surface characteristic of Scenedesmus. Two striations as the longitudinal         axis can be seen on the surface of each of the inner cells. Opposite spines         regularly distribute around the spherical cell of living algae Chlorococoum         (Fig. 4b). All two species of the above algal cells appeared in the pictures         shrink a little compared to the living cells, because of the drying process         during pretreatment needed for SEM tests. Results of the comparison of         SEM micrographs between algal cells before and after pretreatment with         ferrate demonstrated that the ferrate preoxidation induced a number of         clearly discernible effects on algal behavior and cell architecture. The         treatment caused the
        release of intracellular component into the surrounding
        medium (Figs. 5a and 6a). This phenomenon possibly caused by ferrate stimulation         on algal cell or cleaved sheath by ferrate oxidation. Algae may release         organic compounds into water, that are species-specific and growth phase-specific.         It is reported that extracellular
        organic matters (EOM) from cultures of green and bluegreen algae and diatoms         behave like anionic and nonionic polyelectrolytes [21]. Therefore, it         is suggested that algal biopolymers secreted in response to ferrate oxidation         behave as a coagulant aid.
        Another result of ferrate’s effect on algal cells was the intense sheath         convolutions. SEM micrographs (Figs. 5b and 6a) showed that the cell surface         architecture was eminent damaged, row organization of warts of Scenedesmus         were not remained and the spines fell off
        from the Chlorococoum.
        What is special in potassium ferrate preoxidation is the formation of         ferric hydroxide [(Fe(OH)3] colloids after it is decomposed. Fig. 5c shows         that Fe(OH)3 possibly precipitates on the algae surface. These precipitates         can obviously change algal surface properties. Once it is attached to         the algal surface, the weights
        of the algal cells is increased and the algae settling character is improved,         which have been observed in the process of coagulation. In addition, the         Fe(OH)3 colloids increased the concentration of particles in water, which         is too low to cause effective coagulation.
        Conglomeration of algal cells was also observed after pretreatment with         ferrate (Fig. 6b). It was suggested that
        preoxidation with ferrate enhanced the coagulation (Fig. 1) through the         modification of algae envelope and their behavior as well, thus reducing         the stability of algae colloids.
        3.3. Effects of ferrate preoxidation on UVA
        Ultraviolet absorbance was used to indicate the variation of concentration         and the chemical changes of DOM before and after treatment, because DOM         is one of the most important factors of water quality that affects coagulation.         Fig. 7 shows the comparison of UVA at 254nm with and without alum coagulation         in various preoxidation time. UVA at 254nm of the samples increased after         ferrate oxidation at a very short contacting time (as 1 min, similar to         Fig. 2), and varied smoothly with the continuing extension of oxidation         time. However, UV absorbance decreased after following coagulation-sedimentation         process, and it also varied slightly with the extension of oxidation time.         It means that ferrate preoxidation possibly increased the dissolved organic         concentration of cultured solution or changed the chemical structure of         DOM. This result also suggests that the increment can be removed by following         alum coagulation. Residual DOM concentration
        preoxidized with ferrate followed by alum coagulation is lower than that         without ferrate pretreatment. Corresponding to Fig. 7, scanning of UVA         from 200nm to 320nm shows the same information (see Fig. 8). Figs. 7 and         8 together with Figs. 5a and 6a possibly support that algal biopolymers         secreted in response to ferrate preoxidation, which may behave as a coagulant         aid.
        Fig. 9 shows the effects of ferrate preoxidation on algae removal and         the variation of UVA at 254nm of filtered samples. It can be seen that         the large change
        of three curves occurred during the first 1 min of preoxidation time corresponding         to the phenomenon that ferrate decomposed while its characteristic violet         disappeared soon after injection. During the prolonged preoxidation time         (e.g. longer than 1 min), algae removal
        increased gradually comparing to the smoothly variation of UVA at 254         nm. It demonstrated that ferrate preoxidation inactivated the algal cells         in a very short contacting time and then the algae architecture was destroyed         (Fig. 5b), in consequence, the cellar components
        were released to act as coagulant aid (Figs. 5a and 6a), which largely         enhanced the following coagulation. Induced coagulant aid and the ferric         hydroxide [Fe(OH)3] colloids derived from the decomposition of ferrate         caused the conglomeration of algal cells (Fig. 6b) in prolonged preoxidation         time, leading to the primary coagulation of algae, which also enhanced         the following algae coagulation by alum (Fig. 2).
        4. Conclusions
        Laboratory studies using algae-bearing lake water and cultured algae solution         demonstrated that pretreatment with potassium ferrate obviously enhanced         the algae removal by coagulation-sedimentation process with alum [Al2(SO4)3          18H2O]. Algae removal efficiency
        increased remarkably even at a short period of preoxidation time, and         the efficiency was further increased at a prolonged contact time. To achieve         a certain extent of algae removal, pretreatment with ferrate can reduce         the dosage of alum required to cause
        an efficient coagulation and filtration.
        Efficient removal of algae caused by potassium ferrate preoxidation and         coagulation with alum is suggested to be a consequence of several process         mechanisms. Ferrate preoxidation inactivated algae, and also induced coagulant         aid secreted by algal cells. Meanwhile, ferric
        hydroxide derived from the decomposition of ferrate improved the coagulation         condition by increasing particle concentration in water. In addition,         ferrate preoxidation caused algae agglomerate formation before the addition         of coagulant, and the subsequent application of alum resulted in further         coagulation.
        Acknowledgements
        This work was supported by the National Natural Science Foundation of         China under the scheme of National Science Fund for Distinguished Young         Scholars (Project number 59825106 ).
        References
        [1] Elder JF, Horne AJ. Copper cycles and copper sulphate algicidal capacity         in two Californian lakes. Envir Mgmt 1978;2:17–30.
        [2] Fitzgerald GP. Laboratory evaluation of potassium permanganate as         an algicide for water reservoirs. J South West Water Works Assn 1964;45:16–25.
        [3] Kemp HT, Fuller RG, Davidson RS. Potassium permanganate as an algicide.         J Am Water Works Assoc 1966;58:255–63.
        [4] Bare WFR, Jones NB, Middleebrooka EJ. Algae removal using dissolved         air flotation. J Water Pollut Control Fed 1975;47:153–69.
        [5] Borchardt JA, O’melia CR. Sand filtration of algae suspension. J Am         Water Works Assoc 1961;53:1493–508.
        [6] Fetrusevski B, Van Breemen AN, Alaerts G. Effect of permanganate pre-treatment         and coagulation with dual coagulants on algae removal in direct filtration.         J Water SRT-Aqua 1996;45:316–26.
        [7] Ma J, Graham N, Li GB. Effectiveness of permanganate preoxidation         in enhancing the coagulation of surface waters-Laboratory case studies.         J Water SRT-Aqua 1997; 46:1–11.
        [8] Ma J, Li GB. Laboratory and full-scale plant studies of permanganate         oxidation as an aid to the coagulation.Water Sci Technol 1993;27:47–54.
        [9] Ma J, Li G, Chen ZL, Xu XG, Cai GQ. Enhanced coagulation of surface         waters with high organic content by permanganate preoxidation. IAWQ/IWSA         Joint Specialized Conference. Particle Removal from Dams &Reservoirs.         15–18, February, 2000, Durban, South Africa,2000.
        [10] Sukenik A, Teltch B, Wachs AW, Shelef G, Nir I, Levanon D. Effect         of oxidants on microalgal coagulation. Water Res 1987;21:533–9.
        [11] Wood RH. The heat, free energy and entropy of the ferrate(VI) ion.         J Am Chem Soc 1958;80:2038–41.
        [12] Gilbert MB, Waite TD, Hare C. An investigation of the applicability         of ferrate ion for disinfection. J Am Water Works Assoc 1976;68:495–7.
        [13] Schink T, Waite TD. Inactivation of f2 virus with ferrate(VI). Water         Res 1980;14:1705–17.
        [14] Fagan J, Waite TD. Biofouling control with ferrate(VI). Environ Sci         Technol 1983;7:23–125.
        [15] Decula SJ, Chao AC, Smallwood C. Ames test of ferrate treated water.         J Environ Eng 1983;109:1159–67.
        [16] Goff H, Murmann RK. Studies on the mechanism of isotopic oxygen exchange         and education of ferrate(VI) ion (FeO4 2). J Am Chem Soc 1971;93:6058–65.
        [17] Owen DM, Amy GL, Chowdhury ZK, Paode R, McCoy G, Viscosil K. NOM         characterization and treatability. J Am Water Works Assoc 1995;87:46–63.
        [18] Ives KJ. Electrokinetic phenomena of planktonic algae. Proc Soc Water         Treat Exam 1956;5:41–53.
        [19] Ma J, Liu W. Enhanced coagulation of low temperature and low turbidity         water by ferrate composite chemicals. Water Wastewater Eng 1997;23:9–11         (in Chinese).
        [20] Staehlin LA, Pickett-Heaps JD. The ultra-structure of Scenedesmus         (chlorophydeae). I. Species with the “reticulate” or “wary” type of ornamented         layer. J Phycol 1975;11:163–85.
        [21] Bernhart H, Clasen J. Flocculation of micro-organisms. J Water SRT-Aqua         1991;40:76–87.
        [22] Narkis N, Rebhun M. The mechanism of flocculation processes in the         presence of humic substances. J Am Water Works Assoc 1975;67:101–8.
相关推荐
- Effects of Slow-Mixing on the Coagulation Performance of Polyaluminum Chloride (PACI)
- Degradation of azo dye C. I. Reactive Black 5 by composite ferrate solution
- Enhanced2coagulation for algae removal from enrich2nourishment water
- Removal of Turbidity, Algae and CODMn Simultaneously by the
- Fenton’s process for simultaneous removal of TOC and Fe2+ fr
- Effectiveness and mechanism of potassium ferrate(VI)
